Poppin' the cherry...
Mikey
Post by Mikey »
Well, I got my first taste of river water Sunday. Gretchen was nice enough to call me on Saturday and see if I wanted to run. Her, Cindy, and Odelle were nice enough to let me join them for an upper James run. So I met them at Reedy Creek, we loaded up the boats on my truck, and on up to Pony Pasture.
So... let's start by falling in the water trying to get into the boat. No bruises, nothing lost, OK... later I asked Gretchen "So, does it count as a swim if I never actually made it into the boat?" She said yes. Well, now that that's out of the way, let's try again. Once you're already in the water, it's much easier to find a place to stick the boat and get in... I guess. That's my story and I'm sticking to it. And as Odelle said, a wetsuit doesn't work until it's wet.
So, finally in the boat, Odelle was showing Cindy some ferrying techniques, and I just followed around and tried to get used to having the boat on moving water. And Odelle was trying out a new boat, which he said he really liked - a Wavesport I think? It took some getting used to, but I eventually felt pretty good about things. I did find out that the rec boat I bought, the Pungo 120, is like turning a semi compared to a whitewater boat's Mini Cooper. Actually, a better analogy is the rec boat's like a Mustang, and the whitewater boat's like a Porsche. I can move a lot faster in a straight line than the ww boats, but turning quickly - forget about it.
I felt good about myself going through the first small rapids, got into Powhite Ledges and got stuck between rocks that I saw too late (this will be a recurring theme). Odelle talked me through getting my boat over/through the rocks, and I didn't swim. Then I got stuck in the shallows under the bridge, but I got out. Then we went through choo-choo. Odelle was great about explaining where I should head, but when I got there I tried to make a quick turn to avoid a rock, got sideways on the rock, and went over. The three of them helped me get back into the boat - Cindy remarked how it was great to see some of the maneuvers they had practiced in action - glad I could oblige :shock: ... But in the end, I kept my hat, my sunglasses, all appendages, my paddle and my boat, thanks to all that were around. Boy that water was cold... The new wetsuit I had bought kept me plenty warm, but my arms and feet (where the wetsuit wasn't) got cold mighty quick. We paused for a break after choo-choo. Luckily it was warm outside - out of the water, my feet eventually thawed out.
So, on we go to the low-head dam below choo-choo. Odell again did a great job guiding me to ferry across choo-choo and down to the dam. He explained where I needed to head, and I made it through with no issues.
At Mitchell's gut, I let Gretchen and Cindy go through, and then found my line and went for it. I felt good about my progress through until I hit an unseen rock and took another swim.
So, River 3, Mikey 1? It didn't feel too bad for a first attempt, but I definitely learned a few things -
1. There's no substitute for good people helping you down a river.
2. Cold water is cold. Real cold.
3. Any rock can catch you. Also, they are stubborn and rude, and very unlikely to move out of your way to let you pass by.
4. Rec boats move fast and turn slow, making it hard to get out of a mistake once you've made it.
5. Getting sideways in a current is BAD. See 3 and 4.
6. Boats without skirts fill up fast. I'm sure that had a lot to do with why I flipped so quickly, once 5 happened, I couldn't correct because of 4, and then 3.
7. Boats without skirts that are full of water are HEAVY.
Thanks again to all who let me slow them down, I look forward to smoother runs in the future.
AndyLee
Class III
Class III
Post by AndyLee »
Hey Mikey, Great trip report, just remember we're all between swims:oops: I did a little of it yesterday myself and you're right, the water is Damn Cold, even with the wet suit on.
Now about that Pungo.....well, there's a couple good deals on ww boats in the classifieds....anybody who can write trip reports this well deserves a good boat bn
Never let the absolute truth get in the way of a damn good story:)
grannyyaker
Post by grannyyaker »
Great trip report Mikey. I see that I missed the best part of the trip. My husband used to fall into the water getting out of his boat, so we always count any unintentional fall into the water as a "swim". I had a great time on the river with you. Let's do it again when the water's a little warmer and you have a skirt for the boat to help keep out the water that threw you off balance :)
A friend is someone who thinks you're a good egg even when you're slightly cracked.
cincorswim
Mikey's Day Out
Post by cincorswim »
Great trip report, Mikey! It was tons of fun and I was a bit envious of the speed with which you went downriver. You have a great attitude about all of it and don't seem scared off at all by having to swim in the cold, cold water.
Another great day on the river - thanks to ALL.
Happy HollyDays,
Cindy
dougp
Swim
Post by dougp »
Gretchen, I do remember that as ?Larry rule? #6. So it must be counted as a swim, unless you feel a ?Larry waiver? is in order. That was rule #1 as I remember it. Larry would have most likely given him a break since it his first time out. But he would have certainly had a good laugh first. What do you think?
[/quote]My husband used to fall into the water getting out of his boat, so we always count any unintentional fall into the water as a "swim".
cincorswim
Larry
I sure wish I could've met Larry. Sounds like a great guy.
(Sorry to highjack the thread <------ is that what this is called?)
jules
Re: Larry
Post by jules »
cincorswim wrote:I sure wish I could've met Larry. Sounds like a great guy.
Only if it starts a subthread that has nothing to do with the original thread and throws the orig. off topic, but I think it's ok this time. :wink: I would have liked to have met Larry as well - he sounds like a great guy!
Great report! Weighing in on the pungo discussion - I'd agree with your original assessment: pungo = semi as it does go fast in a straight line (think about I-81 and going only 10 miles over the speed limit in your car - they are fast). I'd agree with Andy that if you like whitewater, consider adding a whitewater boat to your stable. You'll want to keep the pungo for flatwater.
John
Post by John »
Horray for new paddlers. You'll be able to help others who are falling out of their boats in no time. And, what better incentive to stay in your boat than cold water?
There aren't a lot of us who love the Upper. I do. I look forward to paddling with you.
-John
