Cacapon River Fall Colors... Paw Paw Bends. Sat Oct 25
- larry gross
We'll run the Cacapon, from Coldstream (downstream from Rt 50 Capon Bridge) to 127 Bloomery Pike takeout (Caudy's Castle) - unless water is too low, then we'd do the lower Cacapon or Paw Paw Bends on the Potomac River... minimal white water but fall colors scenic - 10-12 miles or so in distance.. figure 3-5 hours on water beyond shuttle time.
we'll likely meet at the 127 takeout at 10am unless changes are made, keep in touch to get latest details.
we need at least 3 people and two cars to make the trip!
thanks.
thanks.
- larry gross
no.. it's a crap shoot!Daryl wrote:Larry - do you have a gauge minimum for the Coldstream to Rt 127 section that you go by? I see AW shows its running, but it uses a South Branch gauge instead of a Capacon gauge.
if you can get your way through the Coldstream shallows.. you can go the rest!
paddling is an adventure!
